John deere 3720 question
/ John deere 3720 question #1
Dan Hunter
Enid, OK
2012 John Deere 3720 eHydro
Whats the diameter on the drawbar hole on the implement side? I don't intend to haul stuff around but merely be able to move my trailer and need to put a ball on it.
/ John deere 3720 question #2
Per JD Parts
Part Number: M123824
Description: Drawbar - DRAWBAR, NA
Specification
Weight: 14.84 LBS 6.73 Kg
Hole Size - Tractor End 0.827 IN
Hole Size - Towed End 1.024 IN
Length 27.559 IN
Thickness 1.000 IN
Width 2.000 IN
No. Holes At "A" Tractor End 3.000 UNITY
Hole Location - Tractor End 1.953 IN
Hole Location - Towed End 1.181 IN
Material 4140
Finish K
/ John deere 3720 question #3
Puzzling to me... seems the Tractor End and the Towed End are the same.. but maybe the Towed End is what I think would be called the Towing End. Putting the ball on the Towing End. :confused2:
/ John deere 3720 question #4
You can verify which end is which by checking the distance from the end to the hole per the specifications.
/ John deere 3720 question #5
Measured mine on the 4300 and the diam is 1 " and the 0.998" threaded end of the 2" ball fits perfectly.
Thanks so much for your efforts. I'm on it.
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
1982 LOADSTAR LS25LB 96"X30' DOVETAIL TRAILER (A59823)
1982 LOADSTAR...
