John deere 3720 question
/ John deere 3720 question #1
Dan Hunter
Enid, OK
2012 John Deere 3720 eHydro
Whats the diameter on the drawbar hole on the implement side? I don't intend to haul stuff around but merely be able to move my trailer and need to put a ball on it.
/ John deere 3720 question #2
Per JD Parts
Part Number: M123824
Description: Drawbar - DRAWBAR, NA
Specification
Weight: 14.84 LBS 6.73 Kg
Hole Size - Tractor End 0.827 IN
Hole Size - Towed End 1.024 IN
Length 27.559 IN
Thickness 1.000 IN
Width 2.000 IN
No. Holes At "A" Tractor End 3.000 UNITY
Hole Location - Tractor End 1.953 IN
Hole Location - Towed End 1.181 IN
Material 4140
Finish K
/ John deere 3720 question #3
Puzzling to me... seems the Tractor End and the Towed End are the same.. but maybe the Towed End is what I think would be called the Towing End. Putting the ball on the Towing End. :confused2:
/ John deere 3720 question #4
You can verify which end is which by checking the distance from the end to the hole per the specifications.
/ John deere 3720 question #5
Measured mine on the 4300 and the diam is 1 " and the 0.998" threaded end of the 2" ball fits perfectly.
Thanks so much for your efforts. I'm on it.
