John Deere 3203 won't start
   / John Deere 3203 won't start #1
jc1960
Orting, wa
John Deere 3203
I have a 2006 John Deere 3203 that has been relatively free of issues but within the last week after being used the tractor sat for a few days and then would not start. Since it was the original battery I replaced it and found no difference. After looking I noticed the ignition fuse was blown so I replaced it and when I turned the key partway the instrument panel came on but when I tried to start there was a click / clunk and the fuse blew again. This repeated twice, any suggestions or has anyone else had this issue?
thanks
   / John Deere 3203 won't start #3
What's the location of the fuse that keeps blowing? Like F1 or what??
   / John Deere 3203 won't start #6
Ok that's the one I thought it might be. I'll do some looking into tomorrow on the schematics. I'll be in touch
I pulled the starter and if I turn clock ways it turns freely, if I turn counter clock ways it extends and turns.
   / John Deere 3203 won't start #8
Something similar happened to me recently. It was corrosion on the battery cable attached to the starter. I would just hear a click when turning the key.
   / John Deere 3203 won't start #9
When out does the starter respond when key is turned?
Will the flywheel turn?
I tried to see what would happen with the starter out and nothing happened, would I need to get it grounded to the frame? I took the starter in to the dealer and they tested it and said it was fine, I talked to the tech and he said it sounded like I might have a short in the system and said it could possibly be the ignition switch. For 45 bucks I bough a new one and if it quits pouring rain I will try and figure out how to get to it.
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
INGERSOLL RAND 100KW GENERATOR (A50854)
INGERSOLL RAND...
1999 24DTA pintle hitch trailer (A51039)
1999 24DTA pintle...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
2000 WINNEBAGO FORD F550 RV (A50854)
2000 WINNEBAGO...
Unused 2025 CFG QNT50R Mini Excavator (A49461)
Unused 2025 CFG...
