John Deere 3203 won't start
   / John Deere 3203 won't start #1
jc1960
Orting, wa
John Deere 3203
I have a 2006 John Deere 3203 that has been relatively free of issues but within the last week after being used the tractor sat for a few days and then would not start. Since it was the original battery I replaced it and found no difference. After looking I noticed the ignition fuse was blown so I replaced it and when I turned the key partway the instrument panel came on but when I tried to start there was a click / clunk and the fuse blew again. This repeated twice, any suggestions or has anyone else had this issue?
thanks
   / John Deere 3203 won't start #3
What's the location of the fuse that keeps blowing? Like F1 or what??
   / John Deere 3203 won't start #6
Ok that's the one I thought it might be. I'll do some looking into tomorrow on the schematics. I'll be in touch
I pulled the starter and if I turn clock ways it turns freely, if I turn counter clock ways it extends and turns.
   / John Deere 3203 won't start #8
Something similar happened to me recently. It was corrosion on the battery cable attached to the starter. I would just hear a click when turning the key.
   / John Deere 3203 won't start #9
When out does the starter respond when key is turned?
Will the flywheel turn?
I tried to see what would happen with the starter out and nothing happened, would I need to get it grounded to the frame? I took the starter in to the dealer and they tested it and said it was fine, I talked to the tech and he said it sounded like I might have a short in the system and said it could possibly be the ignition switch. For 45 bucks I bough a new one and if it quits pouring rain I will try and figure out how to get to it.
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2001 KENWORTH T800 TRI AXLE TANKER TRUCK (A51222)
2001 KENWORTH T800...
2014 MACK CXU (PINNACLE) (A50854)
2014 MACK CXU...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2015 Ram 1500 Crew Cab Pickup Truck (A49461)
2015 Ram 1500 Crew...
