John Deere 318 starter problem
   / John Deere 318 starter problem #1
rdlillemoen
Roseville, MN
318 John Deere
My JD 318 starter would have to click (by turning key to start) 10-20 times, before it would engage. Sure sounded like a solenoid /starter problem. I replaced the starter/solenoid with a new one, but same problem with a few less clicks. I then ran across the answer in a Dealer Technical Assistance Center bulletin (DTAC- #12935). It recommended installation of a repair kit, which was basically a relay that can carry more current to the starter/solenoid from the battery. Kit is part # AM107421 (JD), easy to install, problem solved. Too bad I didn't find that info earlier...saved cost and aggravation of replacing starter. RDL
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A51039)
2023 New Holland...
2001 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2001 Big Tex 10PI...
2014 KENWORTH T800 MIXER TRUCK (A50854)
2014 KENWORTH T800...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
JOHN DEERE 450H CRAWLER DOZER (A51406)
JOHN DEERE 450H...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
