John Deere 300x Loader - Will not dump
/ John Deere 300x Loader - Will not dump #1
Thowle
Kentucky
John Deere 4066R Cab w/ H180 and 4-in-1 Bucket
Used the 3520 to bush-hog today; some trees/saplings that got pushed over with the loader.
After about 5 hours of mowing, went to shut tractor down and level out the bucket.. it will raise, lower, and tilt back, but it will only dump about 1" then you can hear the hydraulic strain. Any ideas? Figured maybe a stick or something was wedged between the arms and the bucket, but didn't see anything.
/ John Deere 300x Loader - Will not dump #2
I would unplug and reseat the quick connects. That fixes 99% of "my loader doesn't xxxx". If that doesn't fix it, swapp the lift hoses around with the curl hoses, and try to isolate the problem to the loader or the tractor.
/ John Deere 300x Loader - Will not dump #3
Did the lock lever get moved? Right side in front of joy stick.
/ John Deere 300x Loader - Will not dump #4
Ditto on possible hyd QD problem. Possible tree/sapling damage to FEL valve control cable.
Not the QD's... everything looks fine. Took bucket off today and tried to extend arms (dump), and there is a lot of resistance after about 1". My buddy thinks one of the rams is bent. Guess time to take to JD.. that plus the AC quit working!
/ John Deere 300x Loader - Will not dump #6
Don't mess with it too much without a bucket on. If one ram is bent, the healthy one will shear the timing rod pin. Or take the timing rod pin out for now
Maybe they are both bent, because we took that timing rod off, and they both stayed about the same.
/ John Deere 300x Loader - Will not dump #8
They make look fine, but do unplug and plug back in all 4 quick couplers!
If rods are bent they will still go in an out, unless its an extreme bend like 90 degrees.
/ John Deere 300x Loader - Will not dump #9
Yes, I agree. If you bent both rods you would have noticed.
You all were right! Took the QDs off, and re-seated, and now she works like a charm!
/ John Deere 300x Loader - Will not dump #11
Like Arlen wrote: 99% of the time...
/ John Deere 300x Loader - Will not dump #12
I had the same problem on my 400x. It happens,
D.
/ John Deere 300x Loader - Will not dump #13
I have a 3520 with a 300x that won't curl the bucket at all. Loader lift arms work fine. I've checked the quick connects, switched the lift/bucket lines, checked fluid, etc. I think there is an issue with the spool valve. Going into the repair shop this week.
/ John Deere 300x Loader - Will not dump #14
Check the regen - normal - lock lever under the loader joystick - it may have gotten kicked into lock in which case the bucket won't move.
KBH Tender Trailer (A63689)
KBH Tender Trailer...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
2015 Toyota RAV4 SUV (A61574)
2015 Toyota RAV4...
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
2008 HEARTLAND RV CYCLONE 40 FOOT TOY HAULER (A59914)
2008 HEARTLAND RV...
HD 24ft Free Standing Corral Panel with Feed Bunk (A65583)
HD 24ft Free...
