John Deere 2950 Hydraulic Pump Coupler
/ John Deere 2950 Hydraulic Pump Coupler #1
bigblock76
Bronze Member
Little Britain, Ontario
John Deere 2120, John Deere 3140, John Deere 2950, John Deere 7700 Combine, John Deere STX38
Hello,
Should you be able to turn the coupler cw or ccw at all? I'm starting to hear a knock up front, and I'm able to turn the coupler a tad. Its not loose, but I'm wondering if the cushion is worn.
Should there be any play in it or will a new cushion fix that?
/ John Deere 2950 Hydraulic Pump Coupler #2
Replace the cushion. It will only get worse. You are lucky it is a 50 series. The 30 and 40 series are a PITA to change out!
I took a dive into the front end this morning. Out came the A/C condenser, rad. hoses & lines. The hydraulic pump input shaft had a bad leak so I took the pump right out. Took a look at the cushion and its all mangled so I'm glad I got to it.
I'll need some time to rebuild the hydraulic pump before I get this thing all back together. What a day.
/ John Deere 2950 Hydraulic Pump Coupler #4
7700 Combine? I had a turbo but sold it to the Mexicans. You want to buy an 8630? :) I have a 331 30' disk to go with it.
That 7700 runs real nice. A/C works nicely as well.
8630... My 2950 and 3140 keep me humble enough :)
