John Deere 2720
/ John Deere 2720 #1
Kubota B7800
Kubota B7800
I just bought a 2720 with a 200cx loader and a 46 backhoe attachment. The tractor has one leak around the rear end and the backhoe has several leaks. Does anyone have a pdf service manual that you would share?
/ John Deere 2720 #2
It's still a current production tractor and the manual is available through Deere at JDparts.com. Basically it's illegal to do what you are asking and would be against the rules of the forum so you may not get many offers....
The parts diagrams are also available on JDparts so you may be able to look at them and figure out what you need as well. If you can positively identify the area where it is leaking you should easily be able to check for loose bolts or at least identify which gasket is leaking unless it's the power beyond hook up that's leaking from a bad o-ring. Unhook all the hydraulic quick connects and clean and inspect them.
LOAD OUT AND SHIPPING (A65579)
LOAD OUT AND...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2007 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2007 WELLS CARGO...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2015 Cat D6T LGP Dozer (A62679)
2015 Cat D6T LGP...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
