John Deere 2520 Diverter Kit
   / John Deere 2520 Diverter Kit #21
Thanks for the info.
That was kinda the answer I was expecting but I was hoping for something else.
So...
What a guy would need is
  • a (3 way?) solenoid valve for each of the 4 hyd lines that leave the DSCV en-route to the FEL
  • a toggle switch to fire the solenoid valves
When you hit the switch, hydraulic fluid would be diverted from the FEL to the TNT (or whatever) thus allowing you to use the joystick on the factory DSCV valve.
Anybody know of at 12 Volt solenoid stack that could be used for this setup?
If the parts are available, this would be an alternative to adding a new manual valve stack with new control levers for TNT (or whatever) functions.
   / John Deere 2520 Diverter Kit #22
2020 John Deere 6145M (A53314)
2020 John Deere...
John Deere 4230 (A53314)
John Deere 4230...
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
CATERPILLAR 535C SKIDDER (A52707)
CATERPILLAR 535C...
2007 MACK CV713 WINCH TRUCK (A55745)
2007 MACK CV713...
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A55788)
2019 Ford F-350...
