john deere 2305
/ john deere 2305 #1
dale 123
john deere 2305
my tractor starts but then dies as soon as i release key cleaned connections good fuel new filter whats up
/ john deere 2305 #2
It sounds like there is an air leak in a hose somewhere in-between the tank and the injection pump. I'd check your hoses and tighten the clams, then bleed the system.
/ john deere 2305 #3
I might look at the wiring for the fuel shutoff solenoid.
/ john deere 2305
Thank you for your idea on the fuel shut off solenoid you don't know if that is what John Deere calls a fuel shut off timer and how to check it,I think that we are on the same page
/ john deere 2305 #5
did you check fuse F2 and the seat switch?
/ john deere 2305
Yea I've checked both
/ john deere 2305 #8
Sorry read it wrong the safety realy is after the fuse and seat switch and you're getting power to the pull-in timer because the tractor is starting.
/ john deere 2305 #9
it almost sounds like the key switch isn't continuing to send signal to the fuel solenoid
to keep it running after release from the crank position,
maybe that can be tested....
/ john deere 2305
Yea ordered new switch so ill cross fingers and hope
/ john deere 2305
Very nice thank you
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2016 CATERPILLAR 289D SKID STEER (A59914)
2016 CATERPILLAR...
2022 EZ-GO ELITE...
2003 Horton Enclosed Office Trailer, VIN # 5E2B1282931010054 (A65563)
2003 Horton...
Water Tank (A62613)
Water Tank (A62613)
2021 Ram ProMaster 3500 Box Truck, VIN # 3C7WRVLGXME588513 (A65563)
2021 Ram ProMaster...
