john deere 2305
/ john deere 2305 #1
dale 123
john deere 2305
my tractor starts but then dies as soon as i release key cleaned connections good fuel new filter whats up
/ john deere 2305 #2
It sounds like there is an air leak in a hose somewhere in-between the tank and the injection pump. I'd check your hoses and tighten the clams, then bleed the system.
/ john deere 2305 #3
I might look at the wiring for the fuel shutoff solenoid.
/ john deere 2305
Thank you for your idea on the fuel shut off solenoid you don't know if that is what John Deere calls a fuel shut off timer and how to check it,I think that we are on the same page
/ john deere 2305 #5
did you check fuse F2 and the seat switch?
/ john deere 2305
Yea I've checked both
/ john deere 2305 #8
Sorry read it wrong the safety realy is after the fuse and seat switch and you're getting power to the pull-in timer because the tractor is starting.
/ john deere 2305 #9
it almost sounds like the key switch isn't continuing to send signal to the fuel solenoid
to keep it running after release from the crank position,
maybe that can be tested....
/ john deere 2305
Yea ordered new switch so ill cross fingers and hope
/ john deere 2305
Very nice thank you
1993 GMC Sierra Pickup Truck, VIN # 2GTEK19K7P1534489 (A65563)
1993 GMC Sierra...
(4) 11R22.5 TIRES ON STEEL WHEELS (A64277)
(4) 11R22.5 TIRES...
JOHN DEERE GATOR (A64277)
JOHN DEERE GATOR...
New/ Unused Landhonor 2 Stage Air Compressor (A65583)
New/ Unused...
2015 Chevrolet Silverado Flatbed Truck, VIN # 1GB4KZC87FF627659 (A65563)
2015 Chevrolet...
2015 FREIGHTLINER CASCADIA T/A DAYCAB TRUCK TRACTOR (A59914)
2015 FREIGHTLINER...
