John Deere 2130 hydraulics scheme
   / John Deere 2130 hydraulics scheme #21
Complicated ?
After many years of working on them I only figgered it for myself that it had 2 sisteemes.
1. Where the oil gets pumped in a constant circel(the low pressure side )
2. The high pressure side is like a reservoir on a hill. If you need something to work you open a tap and you have flow and pressure.
   / John Deere 2130 hydraulics scheme #22
I believe I understand JD's closed center hyd systems a lot better now after reading/posting on tractor discussion forums that back when I served 13 yrs as a JD dealer service manager solving closed center problems.
I finally had time to split it. Here are some pictures. I think the trans pump is shot. IMG_20200605_160044.jpegIMG_20200605_160047_1.jpegIMG_20200605_160110.jpegIMG_20200605_160636.jpegIMG_20200605_160813_1.jpegIMG_20200605_160817.jpegIMG_20200605_160836_1.jpegIMG_20200605_160927.jpegIMG_20200605_160932.jpegIMG_20200605_160949.jpeg
I found the pump, but haven't had any luck so far with that adapter.
   / John Deere 2130 hydraulics scheme #25
Did you do your tests before you oped up the tractor ?
Very big Q !
Golden rule no 1 Do your tests before splitting ! Then you know what to look for !
   / John Deere 2130 hydraulics scheme #27
Sorry to say....rebuild the tractor and do your tests as stated in post 2
It has quite a bit of scarring. I saw a few videos online and they said that it should be glass like smooth. It also has a lot of play in the shaft
Here is a video of it: John Deere 2130 trans pump - YouTube
Today I opened up the cover underneath the steering column. The oil smelled really bad (burnt) and there is quite a bit of grey metal floating inside. The hole highlited on the last photo leads nowhere on the cover.IMG_20200606_123631.jpegIMG_20200606_124106_1.jpegIMG_20200606_124318.jpegIMG_20200606_123913.jpegIMG_20200606_125615.jpeg
   / John Deere 2130 hydraulics scheme #30
You have powersteering. I am willing to help you with this problem. That oilleak can be repaired after solving you main problem. Testing needs to be done !20200606_124712.jpeg
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Lowboy Trailer (A49461)
2019 Fontaine...
1991 Cleveland Equipment Trailer (A50514)
1991 Cleveland...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2015 INTERNATIONAL...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
