John Deere 2020 Swept back axle pivot pins
   / John Deere 2020 Swept back axle pivot pins
I can't get the rear pin to move. I have heated the housing, and hit the pin as directly as possible with a punch through the front bushing hole...nothing. Since the punch cannot be perfectyl in line with the pin, there is deflection. I put a fair amount of pressure on the pin using a bottle jack pushing from the front bushing housing to the rear. I was afraid to use too much that I would break the casting. If I could get some movement there would be hope of removal. I don't want to do it, but might have to leave it for now.
   / John Deere 2020 Swept back axle pivot pins #12
How bad is the pin? I would think/hope the bushing was the "wear" part.
I would guess about 0.030"-0.050". I didn't mic it, but you can see and feel the wear. It didn't wear past the bushing.
   / John Deere 2020 Swept back axle pivot pins #14
Spec is .004 to 010" clearance. So you have a lot of wear.
   / John Deere 2020 Swept back axle pivot pins #15
Do you have room to pound the pin forward? Not to get it out, but break loose with a more direct hit(s)?
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
2015 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2015 INTERNATIONAL...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
(INOP) 2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
(INOP) 2015 FORD...
JCB 532 Rough Terrain Forklift (A56857)
JCB 532 Rough...
