John Deere 2020 Swept back axle pivot pins
   / John Deere 2020 Swept back axle pivot pins
I can't get the rear pin to move. I have heated the housing, and hit the pin as directly as possible with a punch through the front bushing hole...nothing. Since the punch cannot be perfectyl in line with the pin, there is deflection. I put a fair amount of pressure on the pin using a bottle jack pushing from the front bushing housing to the rear. I was afraid to use too much that I would break the casting. If I could get some movement there would be hope of removal. I don't want to do it, but might have to leave it for now.
   / John Deere 2020 Swept back axle pivot pins #12
How bad is the pin? I would think/hope the bushing was the "wear" part.
I would guess about 0.030"-0.050". I didn't mic it, but you can see and feel the wear. It didn't wear past the bushing.
   / John Deere 2020 Swept back axle pivot pins #14
Spec is .004 to 010" clearance. So you have a lot of wear.
   / John Deere 2020 Swept back axle pivot pins #15
Do you have room to pound the pin forward? Not to get it out, but break loose with a more direct hit(s)?
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTVFX1E84NFB46867, Crew Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
2020 DRAGON ESP...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56435)
2022 John Deere...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
