John deere 2010 syncro range?
/ John deere 2010 syncro range? #1
2006gmcdmax
Augusta, GA
Many but mostly ford diesels or ihc or jds
I have a 62 2010 row crop tractor runs great tranny shifts great too. The syncro range is a little noisy is this normal also I'd like to change the fluid in it is there a full plug on the side that you fill too or is there a dipstick? First syncro range seems like a winner though it is diesel too.
/ John deere 2010 syncro range? #2
No dipstick. Hyd/trans oil fill plug is on RH side under platform. It's slanted at about a 45 degree angle. Fill to bottom of threads.
Ok thanks it sounds low on fluid like its chattering do you know anything about the hydros on these
/ John deere 2010 syncro range? #4
Hyd pump is a gear pump behind & below traction clutch. The hyd filter(screen) are notorious for getting dirty and require excellent cleaning in a good solvent and then blown out with air.
How hard is the screen to get to and yeah that's what I have heard
Ok simple enough how full should this system be I'm more of a ford guy have had a few jds none this big though haha
/ John deere 2010 syncro range? #8
IIRC fill to bottom of threads or maybe to top of threads on plug on RH side of trans case.
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
215603 (A63276)
215603 (A63276)
DRIVE WHEEL W/ PUMP (A65054)
DRIVE WHEEL W/...
2017 GENIE GTH-844 TELESCOPIC FORKLIFT (A65056)
2017 GENIE GTH-844...
2020 Bobcat E26 Mini Excavator (A66734)
2020 Bobcat E26...
