John deere 2010 syncro range?
/ John deere 2010 syncro range? #1
2006gmcdmax
Gold Member
Augusta, GA
Many but mostly ford diesels or ihc or jds
I have a 62 2010 row crop tractor runs great tranny shifts great too. The syncro range is a little noisy is this normal also I'd like to change the fluid in it is there a full plug on the side that you fill too or is there a dipstick? First syncro range seems like a winner though it is diesel too.
/ John deere 2010 syncro range? #2
No dipstick. Hyd/trans oil fill plug is on RH side under platform. It's slanted at about a 45 degree angle. Fill to bottom of threads.
Ok thanks it sounds low on fluid like its chattering do you know anything about the hydros on these
/ John deere 2010 syncro range? #4
Hyd pump is a gear pump behind & below traction clutch. The hyd filter(screen) are notorious for getting dirty and require excellent cleaning in a good solvent and then blown out with air.
How hard is the screen to get to and yeah that's what I have heard
Ok simple enough how full should this system be I'm more of a ford guy have had a few jds none this big though haha
/ John deere 2010 syncro range? #8
IIRC fill to bottom of threads or maybe to top of threads on plug on RH side of trans case.
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
Camco Running Gear (A66408)
Camco Running Gear...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
1997 Fontaine FTW-5-8048WSAW 48Ft 34 Ton Flatbed Trailer (A64194)
1997 Fontaine...
