John deere 2010 syncro range?
/ John deere 2010 syncro range? #1
2006gmcdmax
Augusta, GA
Many but mostly ford diesels or ihc or jds
I have a 62 2010 row crop tractor runs great tranny shifts great too. The syncro range is a little noisy is this normal also I'd like to change the fluid in it is there a full plug on the side that you fill too or is there a dipstick? First syncro range seems like a winner though it is diesel too.
/ John deere 2010 syncro range? #2
No dipstick. Hyd/trans oil fill plug is on RH side under platform. It's slanted at about a 45 degree angle. Fill to bottom of threads.
Ok thanks it sounds low on fluid like its chattering do you know anything about the hydros on these
/ John deere 2010 syncro range? #4
Hyd pump is a gear pump behind & below traction clutch. The hyd filter(screen) are notorious for getting dirty and require excellent cleaning in a good solvent and then blown out with air.
How hard is the screen to get to and yeah that's what I have heard
Ok simple enough how full should this system be I'm more of a ford guy have had a few jds none this big though haha
/ John deere 2010 syncro range? #8
IIRC fill to bottom of threads or maybe to top of threads on plug on RH side of trans case.
2003 CASE 590 SUPER M SERIES 2 BACKHOE (A65053)
2003 CASE 590...
Skid Steer Blank U-Plate (A65640)
Skid Steer Blank...
2018 Ford Focus (A61574)
2018 Ford Focus...
White 18' Disc Harrow (A66408)
White 18' Disc...
2022 SANY SY35U EXCAVATOR (A63276)
2022 SANY SY35U...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
