John deere 2010 don't start
/ John deere 2010 don't start #1
sonetiliaia
John deere 2010
John deere injector pump don't work
/ John deere 2010 don't start #2
Welcome to TBN
Do you have good fuel flow from tank to inj pump? Is fuel tank venting. How many hrs of use since fuel filter was changed? Try starting engine with bleeder screw loose on inj pump allowing fuel to escape. Check valve that fuel return line attaches to could be clogged from deteriorating IP drive ring causing too high pressure in IP body. It's possible metering valve or other internal IP parts are stuck from having to use ULSD or Bio-diesel
/ John deere 2010 don't start #3
Yes, how long has it been since it ran last and how old is the fuel. I just got through working on a 410 that the fuel was old and the IP got gummed up. A real mess!! Customer said it ran a couple of months ago, but since sitting in the hot, desert sun, the fuel got real bad. Replaced the fuel, took the pump apart and cleaned all the varnish/gum in the pump to make it run.
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
Pickup Truck Ladder Rack (A62613)
Pickup Truck...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
2015 Freightliner (A64119)
2015 Freightliner...
