Does anyone else have a problem with the 3pt arms rubbing the tires when you lift them all the way up? If you have and fixed the problem let me know?
Thanks biyou
Hi--if you do a search on 2520 and lift arms you will find a ton of info. I believe that JD had a replacement/different set of 3pt lift arms (sometimes replaced under warranty).
