john deere 1520 hydraulic power steering problem
   / john deere 1520 hydraulic power steering problem #11
Does 1520 clutch pedal have any free travel? As a rule MF 165's are good tractors. I personally don't like MF's hyd systems but my repair knowledge for MF hyd's is limited.
   / john deere 1520 hydraulic power steering problem #12
design of the the john deere hydraulic the transmission/main hydraulic charge pump is driven with the transmission input shaft. So when depressing clutch all the way down you are shutting off this pump. The main hydraulic will operate for a short period with clutch down.
   / john deere 1520 hydraulic power steering problem #13
SORRY 4020deereboy but on a JD utility tractor such as a 1520 you are incorrect as the trans pump is driven from the pto input shaft not the traction shaft!!!!!!!!!!
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
2018 JLG 4045R 40ft Electric Scissor Lift (A55787)
2018 JLG 4045R...
2015 Ford Focus (A51694)
2015 Ford Focus...
