john deere 1520 hydraulic power steering problem
   / john deere 1520 hydraulic power steering problem #11
Does 1520 clutch pedal have any free travel? As a rule MF 165's are good tractors. I personally don't like MF's hyd systems but my repair knowledge for MF hyd's is limited.
   / john deere 1520 hydraulic power steering problem #12
design of the the john deere hydraulic the transmission/main hydraulic charge pump is driven with the transmission input shaft. So when depressing clutch all the way down you are shutting off this pump. The main hydraulic will operate for a short period with clutch down.
   / john deere 1520 hydraulic power steering problem #13
SORRY 4020deereboy but on a JD utility tractor such as a 1520 you are incorrect as the trans pump is driven from the pto input shaft not the traction shaft!!!!!!!!!!
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
40ft Sea Container (A52384)
40ft Sea Container...
UNUSED FUTURE WS43 - 12" MINI HYD LOG SPLITTER (A54757)
UNUSED FUTURE WS43...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2020 Ford F-150 Crew Cab Pickup Truck (A53422)
2020 Ford F-150...
