john deere 1520 hydraulic power steering problem
   / john deere 1520 hydraulic power steering problem #11
Does 1520 clutch pedal have any free travel? As a rule MF 165's are good tractors. I personally don't like MF's hyd systems but my repair knowledge for MF hyd's is limited.
   / john deere 1520 hydraulic power steering problem #12
design of the the john deere hydraulic the transmission/main hydraulic charge pump is driven with the transmission input shaft. So when depressing clutch all the way down you are shutting off this pump. The main hydraulic will operate for a short period with clutch down.
   / john deere 1520 hydraulic power steering problem #13
SORRY 4020deereboy but on a JD utility tractor such as a 1520 you are incorrect as the trans pump is driven from the pto input shaft not the traction shaft!!!!!!!!!!
Anderson 31ft T/A Flatbed Equipment Trailer (A51691)
Anderson 31ft T/A...
2015 Volvo VNL 64T (A55218)
2015 Volvo VNL 64T...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
BUNDLE OF 82" X 49" DIAMOND PLATE SHEET METAL (A54756)
BUNDLE OF 82" X...
UNUSED XSTAR 101" X 25' BRIDGE PLATFORM (A54756)
UNUSED XSTAR 101"...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
