John Deere 140
   / John Deere 140 #1
cadetman
Ute,Iowa
140 and STX46
Can anyone tell me what happens when the relief valves in a 140 goes bad? Mine works every once in a while and will make the tractor move very slowly when idling but stops moving when the tractor is throttled up.
   / John Deere 140 #2
Hi,i just changed one of my relief valves on my jd 140' when the valve is bad and there is one for forward and reverse, tractor will not move in that direction. you can try and soakin brake fluid because they can get dirty but if that doesn't work you will need to replace the bad valve. there is a place in michigan i believe it is Lj hydraulics and they have the valve for around 66.00. that transmission should be a Sunstran.these valves are about 130 at a john deere dealership. i have to check my notes for the exact info.if you want me to.hope this helped
Feteral 8"x60' Transport Auger (A50774)
Feteral 8"x60'...
FORD 2810 TRACTOR (A51243)
FORD 2810 TRACTOR...
New JMR Skidloader Boom (A50774)
New JMR Skidloader...
2016 Ford E-350 Enclosed Service Van (A50323)
2016 Ford E-350...
2017 CATERPILLAR 304E2 EXCAVATOR (A51242)
2017 CATERPILLAR...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
