John Deere 110 TLB - adjust fwd/rev potentiometers?
   / John Deere 110 TLB - adjust fwd/rev potentiometers? #21
sent
   / John Deere 110 TLB - adjust fwd/rev potentiometers? #22
Just to close this out - we sold the 110 because Deere won't back us up on the electrical system if we can't fix it...to bad because its a great machine mechanically.
   / John Deere 110 TLB - adjust fwd/rev potentiometers? #23
I have a PDF of the tech manual your welcome to, if wanted shoot me your email
Joe
Same problem with a 2006 110. Still have the manual?
   / John Deere 110 TLB - adjust fwd/rev potentiometers? #24
on the way
   / John Deere 110 TLB - adjust fwd/rev potentiometers? #25
try to get the spray to go inside the pot, then actuate the control that rotates the pot a few times..
   / John Deere 110 TLB - adjust fwd/rev potentiometers? #27
on the way
   / John Deere 110 TLB - adjust fwd/rev potentiometers? #28
Joe
Hey Joe... I was told you are the guy to contact. I just purchased a 110 tlb a few weeks back. Today my forward pedal went awY and I have a code with two short flashes and two long flashes. I'm thinking it is the potentiometer. Can you please send me thar manual also? Thanks.
   / John Deere 110 TLB - adjust fwd/rev potentiometers? #29
Glad I could help. It is actually user joecdeere from both forums that supplied the tech info. He has been an invaluable resource for all my JD equipment. I just took a moment to read into your problem and pass along the fix.
Hey Tractor Guy
I have been searching for this calibration procedure as well. Unfortunately the link you have shared in a few post here no longer works. If not too much trouble I would really appreciate that info. Thanks
   / John Deere 110 TLB - adjust fwd/rev potentiometers? #30
Does anyone have any instructions or tech notes on adjusting the forward/reverse potentiometers for the JD 110 TLB?
Nox Vidmate VLC
I haven't gotten the tech manual, but the self-diagnostic code is flashing a code for the Forward pedal potiometer. Sometimes it works, sometimes it doesn't, so i have to move the machine with the creeper switch when it doesn't. The PO said he replaced both fwd/rev potiometers prior to the sale. Anyways, the manual says to contact the JD dealer, but unless you need a factory computer, how hard can it be?
I had a speed sensor code too, and that was very easy to replace, that code doesn't flash anymore.
Hey joe pm sent as well as I am looking at a 110 with a forward pedal that won't return
Rooster Weathervane (A55853)
Rooster...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
