John Deere 1050 Electrical Issues
/ John Deere 1050 Electrical Issues #1
rangerman942
Poplar Bluff, MO
John Deere 1050
I am experiencing electrical problems with my JD 1050. A while back it blew the top off a new battery. I checked the voltage output at the battery and it was charging at 18 volts....too much. I took it to a repair shop for other issues and while it was there I had them check the alternator and it was working properly. So the assumption was the voltage regulator was bad. I purchased a voltage regulator online, note: my old was was a mechanical one, the replacement was a solid state. I have the tractor back now and it's not charging at all. I also notice my fuel gauge doesn't work and my 3 indicator lights won't power up. It starts and runs great until the battery dies and I have to charge it. Any suggestions on where to start trouble shooting. Alll wiring looks good and no shorts anywhere. I have taken off the alternator and voltage regulator and am having them tested on Monday. Hopefully that will tell me what issues I have with charging. Any ideas on the other electrical issues?
thanks in advance.
/ John Deere 1050 Electrical Issues #2
Welcome to TBN
Know how frustrating these problems are to sort out. Sometimes a pig-in-a-poke when ordering online, but then so can be going to a store and learn that being new doesn't mean it is going to work right.
Having a wiring diagram and just working your way along to locate a trouble spot is best I can recommend.
This site will be your best bet for help, and there is vast amount of info in TBN's past, but sometimes searching for it can be a feat by itself.
Seems to take a special skill to search here. But worth a try, IMO.
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
(2) KMC Strip Till Row Markers (A64127)
(2) KMC Strip Till...
New/Unused Landhonor 26ft x 13ft Metal Carport (A65583)
New/Unused...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
John Deere 750C Dozer (A66285)
John Deere 750C...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
