John Deer 318 deck won't engage
   / John Deer 318 deck won't engage #1
BrianCanz
I have a 1993 318 John Deer in excellent condition but the mowing deck won't kick on. The voltage light is on until I flip the deck switch then the light goes out but the deck won't enagage. Any ideas??
   / John Deer 318 deck won't engage #2
Just a guess, but assuming yours has an electric PTO clutch, it sounds like the electric clutch might be shorted, or maybe it's stuck in a bind and it's drawing a lot of current when you switch it on.
If it's not too much trouble to remove, I would pull it off and test it on the bench with a 12VDC power supply.
   / John Deer 318 deck won't engage #3
There is a critical 'Air-Gap' adjustment, that has been problematic to several owners includind 'yours truly' Read my old thread: http://www.tractorbynet.com/forums/...44369-jd-318-intermittent-electro-clutch.html
Also a good Forum at Weekend Freedom Machines: Repowering JD 318
If you need more help, post or PM. I think it's a quick fix with a wrench and feeler gauge...~Scotty
One more link: http://www.weekendfreedommachines.com/discus/messages/335/adjust_PTO_clearance-397278.pdf ~Scotty
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2005 TerraGator 8104 (A55301)
2005 TerraGator...
2004 CAT 953C Crawler Loader (A47477)
2004 CAT 953C...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
