John Deer 318 deck won't engage
   / John Deer 318 deck won't engage #1
BrianCanz
I have a 1993 318 John Deer in excellent condition but the mowing deck won't kick on. The voltage light is on until I flip the deck switch then the light goes out but the deck won't enagage. Any ideas??
   / John Deer 318 deck won't engage #2
Just a guess, but assuming yours has an electric PTO clutch, it sounds like the electric clutch might be shorted, or maybe it's stuck in a bind and it's drawing a lot of current when you switch it on.
If it's not too much trouble to remove, I would pull it off and test it on the bench with a 12VDC power supply.
   / John Deer 318 deck won't engage #3
There is a critical 'Air-Gap' adjustment, that has been problematic to several owners includind 'yours truly' Read my old thread: http://www.tractorbynet.com/forums/...44369-jd-318-intermittent-electro-clutch.html
Also a good Forum at Weekend Freedom Machines: Repowering JD 318
If you need more help, post or PM. I think it's a quick fix with a wrench and feeler gauge...~Scotty
One more link: http://www.weekendfreedommachines.com/discus/messages/335/adjust_PTO_clearance-397278.pdf ~Scotty
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A54865)
2014 Ford F-150...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
UNUSED LANDHONOR LHR-RC920 CHAINS & BINDERS (A54757)
UNUSED LANDHONOR...
2017 Polaris 500 Ranger Diesel Utility Cart (A53421)
2017 Polaris 500...
