John Deer 318 deck won't engage
   / John Deer 318 deck won't engage #1
BrianCanz
I have a 1993 318 John Deer in excellent condition but the mowing deck won't kick on. The voltage light is on until I flip the deck switch then the light goes out but the deck won't enagage. Any ideas??
   / John Deer 318 deck won't engage #2
Just a guess, but assuming yours has an electric PTO clutch, it sounds like the electric clutch might be shorted, or maybe it's stuck in a bind and it's drawing a lot of current when you switch it on.
If it's not too much trouble to remove, I would pull it off and test it on the bench with a 12VDC power supply.
   / John Deer 318 deck won't engage #3
There is a critical 'Air-Gap' adjustment, that has been problematic to several owners includind 'yours truly' Read my old thread: http://www.tractorbynet.com/forums/...44369-jd-318-intermittent-electro-clutch.html
Also a good Forum at Weekend Freedom Machines: Repowering JD 318
If you need more help, post or PM. I think it's a quick fix with a wrench and feeler gauge...~Scotty
One more link: http://www.weekendfreedommachines.com/discus/messages/335/adjust_PTO_clearance-397278.pdf ~Scotty
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55218)
Galvanized...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
UNUSED WOLVERINE JMR-22-8.5G 1R RIPPER (A54757)
UNUSED WOLVERINE...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XLT...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
