john deer 285
   / john deer 285 #1
tinnerman
winfield, mo
massey ferguson
HI, I'M NEW ON HERE, BUT I HAVE A 285 THAT KEEPS SPITING OUT GAS AT THE VENT ON TOP OF THE CARBURETOR.I INSTALLED A NEW CARB, COIL,AND FUEL PUMP.RAN GOOD FOR ABOUT 15 MINUTES THEN IT DID THE SAME AS MY OLD ONE???? ANY BODY ??
   / john deer 285 #2
the fuel level is too high if this happens. perhaps the carb is using a plastic needle valve, which swells and sticks, a rebuild kit should have a stainless steel needle valve which won't stick. yeah, sometimes JD messes up trying to make more money!..
   / john deer 285 #3
This tractor is getting along in the years. Perhaps you have a bad intake valve that is allowing high pressure combustion gases to feed back into the carb.
You should do a compression check to see if you have good compression on both cylinders. You also may want to check the valve to rocker gap.
Richard
   / john deer 285
thanks for the info.the old carb that i took off was steel needle valve, but should it have a rubber tip? or it would be metal on metal trying to seat.
   / john deer 285 #5
the rubber tip could be either on the end of the needle valve, or in the carburetor, there isn't enough pressure for a metal to metal valve to work..
Orico 3000 Cook Top (A51573)
Orico 3000 Cook...
HURRICANE 6' X 11' CONTAINER (A51248)
HURRICANE 6' X 11'...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
2018 Club Car Carryall 1700 (A51573)
2018 Club Car...
RING 2 STARTS HERE @ 9:30 AM (A51247)
RING 2 STARTS HERE...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
