john deer 285
/ john deer 285 #1
tinnerman
winfield, mo
massey ferguson
HI, I'M NEW ON HERE, BUT I HAVE A 285 THAT KEEPS SPITING OUT GAS AT THE VENT ON TOP OF THE CARBURETOR.I INSTALLED A NEW CARB, COIL,AND FUEL PUMP.RAN GOOD FOR ABOUT 15 MINUTES THEN IT DID THE SAME AS MY OLD ONE???? ANY BODY ??
/ john deer 285 #2
the fuel level is too high if this happens. perhaps the carb is using a plastic needle valve, which swells and sticks, a rebuild kit should have a stainless steel needle valve which won't stick. yeah, sometimes JD messes up trying to make more money!..
/ john deer 285 #3
This tractor is getting along in the years. Perhaps you have a bad intake valve that is allowing high pressure combustion gases to feed back into the carb.
You should do a compression check to see if you have good compression on both cylinders. You also may want to check the valve to rocker gap.
Richard
/ john deer 285
thanks for the info.the old carb that i took off was steel needle valve, but should it have a rubber tip? or it would be metal on metal trying to seat.
/ john deer 285 #5
the rubber tip could be either on the end of the needle valve, or in the carburetor, there isn't enough pressure for a metal to metal valve to work..
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2002 John Deere 737 Zero Turn (A63116)
2002 John Deere...
1994 GMC Yukon SLE Multipurpose Vehicle (MPV), VIN # 1GKEK18K3RJ733313 (A61165)
1994 GMC Yukon SLE...
4022CFL (A59228)
4022CFL (A59228)
2014 Ford F-550 4x4 Service Truck with Crane, VIN # 1FDUF5HY9EEB69513 (A61165)
2014 Ford F-550...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
