john deer 285
/ john deer 285 #1
tinnerman
winfield, mo
massey ferguson
HI, I'M NEW ON HERE, BUT I HAVE A 285 THAT KEEPS SPITING OUT GAS AT THE VENT ON TOP OF THE CARBURETOR.I INSTALLED A NEW CARB, COIL,AND FUEL PUMP.RAN GOOD FOR ABOUT 15 MINUTES THEN IT DID THE SAME AS MY OLD ONE???? ANY BODY ??
/ john deer 285 #2
the fuel level is too high if this happens. perhaps the carb is using a plastic needle valve, which swells and sticks, a rebuild kit should have a stainless steel needle valve which won't stick. yeah, sometimes JD messes up trying to make more money!..
/ john deer 285 #3
This tractor is getting along in the years. Perhaps you have a bad intake valve that is allowing high pressure combustion gases to feed back into the carb.
You should do a compression check to see if you have good compression on both cylinders. You also may want to check the valve to rocker gap.
Richard
/ john deer 285
thanks for the info.the old carb that i took off was steel needle valve, but should it have a rubber tip? or it would be metal on metal trying to seat.
/ john deer 285 #5
the rubber tip could be either on the end of the needle valve, or in the carburetor, there isn't enough pressure for a metal to metal valve to work..
2017 Chevrolet Cruze Sedan (A61569)
2017 Chevrolet...
2009 Mack GU813 Roll off Truck, VIN # 1M2AX13C59M007359 (A61165)
2009 Mack GU813...
(INOP) 2012 CHEVROLET TAHOE (A59823)
(INOP) 2012...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
2006 GODWIN GHP45KW-RC-45KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
2016 Dodge Charger Sedan (A61569)
2016 Dodge Charger...
