John deer 2020 start problems
/ John deer 2020 start problems #1
calfal
lake charles,la.
kubota l275 power king 14/24 kioti ck27
hi all.. I have a friend with a 1975 jd 2020.. he is having a problem with intermittent start on his tractor. some times it starts with the key switch and sometimes he has to jump the starter solenoid..for some reason I can't find a wiring diagram does jd not have stuff online.. from the key switch there are some wires go to a little sealed box which I don't know what it is.. do these tractors have a start relay??thanks for any suggestions..
/ John deer 2020 start problems #2
Have your friend look for the service tech manual for the 2020. That should help both of you track down the problem.
/ John deer 2020 start problems #3
If battery negative cable is still attached to battery box I suggest to relocate cable attachment to engine block or starter mounting bolt. 2020 came from factory with no extra starter relay but JD offered a kit to field install a starter relay similar to photo below.
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A59911)
2016 INTERNATIONAL...
2013 Ford F-350 Knapheide Service Truck (A61573)
2013 Ford F-350...
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
