Joe44
   / Joe44 #1
Joe44
Maryland
Kubota B7500
I have a Kubota B7500 with a front mounted snow blower. When I went to engage the front PTO, there was some grinding of the gears. The POT shift lever went forward but the PTO did not engage. The rear PTO is engaged at 540 rpm and will not disengage. The lever moves to both the forward and back positions without depressing the clutch.
   / Joe44 #2
Do you use the clutch when shifting the PTO????
   / Joe44
Yes but I sometimes disengage without the clutch.
   / Joe44 #4
Check the linkage for problems. One should use the clutch when shifting plain gears to avoid the grinding.
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
2008 FORD F750 SUPER DUTY BUCKET UTILITY TRUCK (A50854)
2008 FORD F750...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2015 MACK GU713 (A50854)
2015 MACK GU713...
2013 HINO 388 (A50854)
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
