Jinma Instrument Cluster Help
   / Jinma Instrument Cluster Help #1
dhelvey
Wenatchee, Wa
Jinma 284
I recently purchased a 2006 Jinma 284 with the old rectangular instrument cluster. The tach does not work and other gauges work intermittently. I am interested in purchasing and installing a new instrument cluster and wondered if anyone had done this and if they would share the wiring schematic of the old and new style instrument clusters.
Thank you,
Dave
   / Jinma Instrument Cluster Help #2
If your gauges work intermittently I suspect you have a grounding issue somewhere. A power supply issue is also possible but grounding is probably more likely.
   / Jinma Instrument Cluster Help #4
Behind the dash is a favorite habitat for furry little creatures. They eat the insulation and can actually sever copper wires. That would be my first place to look for nonfunctioning/intermittent gages. Do that before buying a new panel.
   / Jinma Instrument Cluster Help #5
The Jinma tach sensor often fails. It's a simple replacement. There's been a lot of discussion over the years.
Case Titan 3530 (A56438)
Case Titan 3530...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
401 (A52706)
401 (A52706)
2018 RoGator 1100C (A56436)
2018 RoGator 1100C...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
