Jinma 354 Hydraulics Pressure relief Questions
   / Jinma 354 Hydraulics Pressure relief Questions
Isn't the 354 power steering powered by a separate PS pump?
Not on mine. Only one pump as shown in the diagram at the start of the thread.
Because the strong-arm steering works, I'm guessing the steering cylinder and the steering gear box are fine. I am thinking some of those missing chunks of pump seals are lodged in the diverter valve. There does not seem to be any rebuild kits for those so I am not sure if I can get it apart.
Has anyone taken the diverter valve (priority valve?) apart?
   / Jinma 354 Hydraulics Pressure relief Questions #13
Got a pic of your diverter/priority valve? They typically have a large hex head cap on one end. Just unscrew it and use a magnetic pickup/retrival tool to pull out the sliding piston. The only seal is at the cap(and the fittings), and is probably an Oring or an oring face seal(ORFS)/Oring washer. Shouldn't be anything inside but the piston and bore like in a spool valve. Crap in there might keep a port from flowing or the piston from sliding when it detects flow out to the steering...
I'll take this to a new thread since its a new issue with details....
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
Vermeer 630A Stump Grinder (A50515)
Vermeer 630A Stump...
2020 Cadillac Escalade 4x4 SUV (A50324)
2020 Cadillac...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
