Jinma 354 Hydraulics Pressure relief Questions
   / Jinma 354 Hydraulics Pressure relief Questions
Isn't the 354 power steering powered by a separate PS pump?
Not on mine. Only one pump as shown in the diagram at the start of the thread.
Because the strong-arm steering works, I'm guessing the steering cylinder and the steering gear box are fine. I am thinking some of those missing chunks of pump seals are lodged in the diverter valve. There does not seem to be any rebuild kits for those so I am not sure if I can get it apart.
Has anyone taken the diverter valve (priority valve?) apart?
   / Jinma 354 Hydraulics Pressure relief Questions #13
Got a pic of your diverter/priority valve? They typically have a large hex head cap on one end. Just unscrew it and use a magnetic pickup/retrival tool to pull out the sliding piston. The only seal is at the cap(and the fittings), and is probably an Oring or an oring face seal(ORFS)/Oring washer. Shouldn't be anything inside but the piston and bore like in a spool valve. Crap in there might keep a port from flowing or the piston from sliding when it detects flow out to the steering...
I'll take this to a new thread since its a new issue with details....
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
2009 Lee-Boy 8510HD Conveyer Feed paver (A52128)
2009 Lee-Boy...
2021 ASV POSI-TRACK RT-120 FORESTRY SKID STEER (A51242)
2021 ASV...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52128)
REYNOLDS 100 - 8...
