Jinma 354 Hydraulics Pressure relief Questions
   / Jinma 354 Hydraulics Pressure relief Questions
Isn't the 354 power steering powered by a separate PS pump?
Not on mine. Only one pump as shown in the diagram at the start of the thread.
Because the strong-arm steering works, I'm guessing the steering cylinder and the steering gear box are fine. I am thinking some of those missing chunks of pump seals are lodged in the diverter valve. There does not seem to be any rebuild kits for those so I am not sure if I can get it apart.
Has anyone taken the diverter valve (priority valve?) apart?
   / Jinma 354 Hydraulics Pressure relief Questions #13
Got a pic of your diverter/priority valve? They typically have a large hex head cap on one end. Just unscrew it and use a magnetic pickup/retrival tool to pull out the sliding piston. The only seal is at the cap(and the fittings), and is probably an Oring or an oring face seal(ORFS)/Oring washer. Shouldn't be anything inside but the piston and bore like in a spool valve. Crap in there might keep a port from flowing or the piston from sliding when it detects flow out to the steering...
I'll take this to a new thread since its a new issue with details....
2007 Hyundai Santa Fe SUV (A49461)
2007 Hyundai Santa...
2021 Delta Redirective Crash Cushion 75000 (A49461)
2021 Delta...
2012 Chevrolet Traverse SUV (A50324)
2012 Chevrolet...
J & M 30' Head Cart (A50514)
J & M 30' Head...
2015 TRANSMASTER LOWBOY TRAILER (A51222)
2015 TRANSMASTER...
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A51222)
2022 INTERNATIONAL...
