Jinma 254 slow turnover
   / Jinma 254 slow turnover #31
We had a guy at work years ago that ran a forklift out of oil and damaged the motor, in order to keep his job he filled the motor up with motor oil after the damage was done and claimed that he did not why the motor was destroyed. Sounds to me like this may be the case here.....After all the motor oil was "Clean as a whistle" perhaps it was never used !! I would interview the crew that used it again separately and see if they all say the same thing ! I bet they seized the motor up and are not up to admitting it !
   / Jinma 254 slow turnover #32
<font color="blue"> the crew said that they topped it off .The oil is clean as a whistle </font>
Hey RKevis,
I guess now the question is: Did they top it off after or before?
The symptoms that you discribe are the same as an an engine starved for oil, but not quiet completely siezed solid.
Pull the dip stick out and see if there are any signs of cooked oil on the dipstick. The oil level would probably have been too low for this sign, but I'm sure that others will know of other signs to look for if this is the case. There may be a burnt smell somewhere maybe.
I hope this is not the case and that you do not have engine damage.
Joe
   / Jinma 254 slow turnover #33
In an effort to bring some good news, parts are reasonable, may be able to get away with some new bearings, and worse case it is a sleeved engine so even if cylinders gauled, you can bring block back to new spec. Complete engines are also available, but cost plus labor on engine replacement may make it easier just to trade the whole tractor and let the dealer fix it in his "down time" (whatever that is, we are still waiting for 2004 down time projects to get done).
Best of luck, let me know if we can help
Gentlemen
Well I got down and dirty with it.
Rod Bearing #1 slightly bad #2 very bad #3 good.
With rod bearings disconnected engine turns freely .
I have not pulled the main bearings ,you can only get to the two middle ones ,but I will change them also.
Tommy at Affordable Tractor has all the parts.I even had him listen to the sound of the starter ,which he did'nt like.
Well problem found but why?It had to have run out of oil or pluged oil passage.I will keep everyone informed.
Ray Kevis
   / Jinma 254 slow turnover #35
Please send us pictures of the damage, I have not opened up the motor on one of these and I doubt that many others have either. I would love to see what the insides of one of these engines looks like.
Thnaks.
/forums/images/graemlins/ooo.gif
   / Jinma 254 slow turnover #36
Well,you know your motors,,,,who woulda thought just cause it turned over slow,the bearings were burnt up,,hope you can get it fixed,,sounds like your a much better mecanic than me,,,,thingy
Good news
After installing wrong bearings I got the correct ones installed and it starts and runs fine! Looks like the rear seal is leaking enough to make it reasonable to have had my crew run it out of oil.How hard is it to change the rear seal?Would stop leak work?
I've also got a hydraulic leak in the FEL valve box when tipping the bucket down.Although the hydraulic fluid makes my leg silky smooth I would like to fix the leak.
Ray
   / Jinma 254 slow turnover #38
The Y385 engine pic I just looked at shows the rear main seal(part no. 66) as a one piece seal that is pressed into the flywheel housing. I would say you would have to split the tractor in two, remove clutch, pressure plate and flywheel assemblies to get to that seal.
What type hydraulic valve are we talking about here. It sounds like a bad O-ring on the dump/rollback spool and that can probably be replaced fairly easilly.
   / Jinma 254 slow turnover #39
<font color="blue">Good news
</font>
Hey Ray,
That's Good news indeed. Glad that you did not have to replace your engine.
On the rear seal, I would check to make sure that the bolts are tight. There is an additive that you can put in oil, that is supposed to treat and swell up gaskets, so that they will seal better, but don't know if it will hurt the engine or not. I use the Castrol Oil for older engines in(Pickup & Motorsickle), that is supposed to have the same type of additive, but in less concentration. I don't have any leaks in my Jinma224 yet, so I haven't put any additives in yet. Except that I use the 85w140 in the transmission, but that is because I am on the Gulf Coast, where the temperatures are on the Warm Side.
If you can loosen up the plates enough to squeeze in some "Yama Bond", into the area where the gasket is at, then that will probably stop the leakage. They use Yama Bond to seal Engine Cases, when they have to be split, to make repairs on the bottom end.
Glad you got it going Ray,
Get your tractors Running &
Have a nice day,
Joe /forums/images/graemlins/cool.gif
   / Jinma 254 slow turnover #40
</font><font color="blue" class="small">( Good news
Pretty smart on bearings now??? lol.. I hear ya !! If it looks like a Rear Main Seal is leaking ?? ...then go ahead and try and do a long term fix. [if you make money with it via your contracting buisness]. Yes, You will have to split the Tractor if it is a One Piece Seal. If you replaced the Rear Main Bearing you should have be able to see what type seal you have. Most two piece seals if have seen......half of it is in the main bearing cap that I removed to replace the bearing. I dont know what bearings you replaced???
Make sure everything is tight.
I Would not try a Mechanic in a can.
Ronald
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
2021 CATERPILLAR 303E CR EXCAVATOR (A51242)
2021 CATERPILLAR...
2018 Dodge Ram 5500 Bucket Truck - 4x4, Versalift VST40, 45FT Reach, Dakota Line Body (A52128)
2018 Dodge Ram...
2008 JLG 600S TELESCOPIC MANLIFT (A51242)
2008 JLG 600S...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
