Jinma 254 slow turnover
/ Jinma 254 slow turnover #41
RAy,
There are two places for the leak to happen, if it is the rear seal, the oil will be coming from inside the bellhousing. If it is the gasket between the bellhousing and the engine block, the oil will be leaking from just in front of the bellhousing.
The bad news is to properly fix either will require the tractor be split, flywheel be removed and if necessary remove the bellhousing and repair the gasket/and or seal...
It is really not as bad as it sounds if you have a couple floor jacks some jack stands and maybe an engine hoist...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A64553)
2025 Wolverine...
New/Unused Mini Quick Attach Auger with Bit (A65583)
New/Unused Mini...
MASSEY FERGUSON 240 TRACTOR (A64278)
MASSEY FERGUSON...
2017 Ford Fusion Hybrid Sedan (A64557)
2017 Ford Fusion...
2015 GMC Yukon XL Denali SUV (A64557)
2015 GMC Yukon XL...
