Tires Jinma 224 Tire width
/ Jinma 224 Tire width #1
johnk
Elite Member
western NY
Kubota GST Grand L3130 w/ 723 loader, Ags
Whats the easiest way to increase the rear tire stance for stability? Switch each tire to the opposite side with wheel weight on inside? The manual leaves a lot to be desired. How many inches will the increase be? Thanks.
/ Jinma 224 Tire width #2
Hard to conclude from your photo John, but it does look like you've got quite a bit of rubber under that fender. What is the sidewall to sidewall outside measurement?
Are your rims bolted to the inside or the outside of the spokes?
//greg//
Ttractor is how it came. It is 50 miles from here and was wondering the ways to increase the spread. Thanks..
/ Jinma 224 Tire width #4
Anyone with axcess to a mill and metal lathe can make a spacer as wide as needed,match it to the axle,bolt it on and bolt wheels on /forums/images/graemlins/cool.gif
Without making a spacer what is the way to get more width. Back to my original post...Thanks..
/ Jinma 224 Tire width #6
JohnK,you can take the centers of the rims off and reverse them and gain about 8-10 inches.Not a big deal to do
Tommy
Affordable Tractor
Thanks. I'm on vacation 2 weeks so when I get up there I'll give it a go.
2019 CATERPILLAR 305E2 CR EXCAVATOR (A65056)
2019 CATERPILLAR...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
Metaltech Climb and Go (A64553)
Metaltech Climb...
2000 PETERBILT 378(INOPERABLE) (A67714)
2000 PETERBILT...
2008 Chevrolet Silverado 2500 Crew Cab (A62613)
2008 Chevrolet...
