Jinma 224 - adding power steering
/ Jinma 224 - adding power steering #1
ohiobenz
Amish Country Ohio
Jinma 224
has anyone done this?
I'm really tired of fighting the steering wheel especially in 4wd.
Have been thinking of using a Ford Ranger steering box and PS pump to keep things simple - and cheap....
The box looks to be almost the same size as the OEM Jinma box and the arm is almost the same length. It would let me keep all the same drag link stuff.
Any thoughts or input is appreciated!!
/ Jinma 224 - adding power steering #2
Do you realize that the engine driven hydraulic pump also powers the rear lift? To add power steering means you'd also have to come up with a priority valve so that you could steer and lift at the same time.
This question - and the one about fitting a bigger hydraulic pump - make wonder if you didn't buy the wrong tool for the job.
//greg//
/ Jinma 224 - adding power steering #3
We have a older 284 tractor that the engine blew up in ,that had side mount steering cylinder and all the parts to put power steering on yours. The question is how much do you want to spend to do this ? Here is what you will need
Steering column
Steering machine
Side mount steering cylinder
Rear mount for steering cylinder
Priority valve
Hoses (5)
Hardline (1)
I have a used Koyker loader and all the brackets also ? Got a trailer ?
If you are interested ,give me a call or e-mail
Tommy
Affordable Tractor Sales
"Your Jinma parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
//greg//
the tractor does everything i want it to... check my list of attachments....
the reason I am looking at retrofitting a Ford Ranger automotive box and pump is that i DONT have to use a priority valve, steering cylinder etc..
bigger hydraulic pump... its just a question... if retrofitting a bigger pump will do a better job of running my implements, why not???
i'm also contemplating adding a small turbo... really easy to do with diesel - boy i bet that raises some concerns about my choice of tractor LOL.
I've had it for 8 years now and worked it hard every year...now its time to do things so i dont have to work as hard....
Steering column
Steering machine
Priority valve
Hoses (5)
Hardline (1)
Tommy
Tommy I do have a trailer...
I dont believe i'm interstd in the 284 steering setup because it would really complicate things.
Drop me an e-mail on the used Koyker setup! I'm tired of shoveling sheep manure into the trailer by hand...
ohiobenzatyahoodotcom
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A62129)
2019 VOLVO A45G...
2023 Posi Track RT25 Compact Track Loader Skid Steer (A61572)
2023 Posi Track...
RoadTec RP190 (A63689)
2022 Posi Track RT25 Compact Track Loader Skid Steer (A61572)
2022 Posi Track...
Hydraulic rail grinder (A61307)
Hydraulic rail...
