Jerky Power Shuttle
/ Jerky Power Shuttle #1
Boss 302
Platinum Member
Va.
Kioti RX6010PS Mahindra 3510 Sold (Gonna miss that ole girl)
I have an RX6010 that is an awesome machine but, am curious as to why it jerks forward when you let the clutch out. I was on a JD today with the power reverser and it was smooth all the way no jerking or lunging whenever letting out the clutch. I know their is a calibration switch for the power shuttle does anyone know if you can calibrate it and remove the jerking motion?
/ Jerky Power Shuttle #2
There should be adjustment info in the workshop manual. If you dont have a manual, give your dealer a call and ask if he could copy the procedure for you.
/ Jerky Power Shuttle #3
If it's a power shuttle you shouldn't use the clutch to start out or go from forward to reverse or back. On mine there is a toggle switch that changes the response engagement time. Other than having to depress the clutch to start I rarely ever use it. Are you sure you have power shuttle?
Yes, I do have a power shuttle and whenever you want to inch forward it is only natural to use the clutch for that type of maneuver, that is when it lunges forward. I used the power reverser on a John Deere and you could inch forward by using the clutch.
/ Jerky Power Shuttle #5
I can send you the procedure from the manual if you like, It is in PDF form and doesn't copy\paste on to here.
That would be great Thorholt, I really do appreciate that. You can email it to boss302428scj@gmail.com.
Thank you very much,
Randall
/ Jerky Power Shuttle #7
I sent you the pages, let me know if you don't get them.
Gregg, thank you so very much that is a big help. It is appreciated.
Randall
/ Jerky Power Shuttle #9
the shuttle on your 6010 is hydrolic and you can decide to use or dont use the clutch to move from forward to backward.
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2013 KENWORTH T800 WINCH TRUCK (INOPERABLE) (A65643)
2013 KENWORTH T800...
Landhonor 3Pt Stump Grinder (A66408)
Landhonor 3Pt...
New/Unused Wolverine Mini Quick Attach Pallet Forks (A65583)
New/Unused...
2006 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64194)
2006 Chevrolet...
2025 Wolverine BC-13-72W 72in Brush Cutter Skid Steer Attachment (A64553)
2025 Wolverine...
