Jerky Power Shuttle
/ Jerky Power Shuttle #1
Boss 302
Platinum Member
Va.
Kioti RX6010PS Mahindra 3510 Sold (Gonna miss that ole girl)
I have an RX6010 that is an awesome machine but, am curious as to why it jerks forward when you let the clutch out. I was on a JD today with the power reverser and it was smooth all the way no jerking or lunging whenever letting out the clutch. I know their is a calibration switch for the power shuttle does anyone know if you can calibrate it and remove the jerking motion?
/ Jerky Power Shuttle #2
There should be adjustment info in the workshop manual. If you dont have a manual, give your dealer a call and ask if he could copy the procedure for you.
/ Jerky Power Shuttle #3
If it's a power shuttle you shouldn't use the clutch to start out or go from forward to reverse or back. On mine there is a toggle switch that changes the response engagement time. Other than having to depress the clutch to start I rarely ever use it. Are you sure you have power shuttle?
Yes, I do have a power shuttle and whenever you want to inch forward it is only natural to use the clutch for that type of maneuver, that is when it lunges forward. I used the power reverser on a John Deere and you could inch forward by using the clutch.
/ Jerky Power Shuttle #5
I can send you the procedure from the manual if you like, It is in PDF form and doesn't copy\paste on to here.
That would be great Thorholt, I really do appreciate that. You can email it to boss302428scj@gmail.com.
Thank you very much,
Randall
/ Jerky Power Shuttle #7
I sent you the pages, let me know if you don't get them.
Gregg, thank you so very much that is a big help. It is appreciated.
Randall
/ Jerky Power Shuttle #9
the shuttle on your 6010 is hydrolic and you can decide to use or dont use the clutch to move from forward to backward.
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2012 Kenworth T660 T/A Sleeper Cab Truck Tractor (A64194)
2012 Kenworth T660...
2004 Brenner DOT 407 Insulated T/A Chemical Tanker Trailer (A64194)
2004 Brenner DOT...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
Chariot Floor Scrubber (A64194)
Chariot Floor...
