JD970 Hydraulic strainer location ??
/ JD970 Hydraulic strainer location ?? #1
kidbuffalo
Caneadea,N.Y.
JD 970
Can anyone help me locate where the hydraulic strainer is on my jd970 ???
/ JD970 Hydraulic strainer location ?? #2
Strainer is key 5
I have the same parts sheet. But I still can't locate it. I thought it would be next to the filler cap, but it isn't. Is it more to the front,down below, can't find the critter !!
/ JD970 Hydraulic strainer location ?? #4
It will be located in front of rear axle trumpet near the bottom of trans case.
Thanks Jim, I think I see it. I'll let you know later today when I drain the fluid .The parts image says it has six bolts. Wish I could put my phone # here and you could text me a pic. I don't think we are allowed. Catch you later
Thanks Jim, That was it !! After I drained the oil, I took off the two bolts that hold the cover on. When I pulled the strainer out I couldn't believe how much metal was on the strainer. I can't believe the hydraulics worked. Now the backhoe operates like new. Again, thanks a million !!!!
/ JD970 Hydraulic strainer location ?? #7
You're very welcome. I'm glad you got it operating although metal in strainer doesn't sound good. Jim
Yeah, quite a bit of metal. I don't think the previous owner ever cleaned it out. Tractor is a 1998 so that's 20 years. Had to do a little work on it. The backhoe had a bent boom . I cut out about 18" of it and welded in new 1/4" steel. Works good now.
KENWORTH CAB AND HOOD (A65643)
KENWORTH CAB AND...
CASE TV450B SKID STEER (A65053)
CASE TV450B SKID...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
40' Shipping Container (A66285)
40' Shipping...
Cowgirl Statue (A64127)
Cowgirl Statue...
