JD970 Hydraulic strainer location ??
   / JD970 Hydraulic strainer location ?? #1
kidbuffalo
Caneadea,N.Y.
JD 970
Can anyone help me locate where the hydraulic strainer is on my jd970 ???
   / JD970 Hydraulic strainer location ?? #2
Strainer is key 5
I have the same parts sheet. But I still can't locate it. I thought it would be next to the filler cap, but it isn't. Is it more to the front,down below, can't find the critter !!
   / JD970 Hydraulic strainer location ?? #4
It will be located in front of rear axle trumpet near the bottom of trans case.
Thanks Jim, I think I see it. I'll let you know later today when I drain the fluid .The parts image says it has six bolts. Wish I could put my phone # here and you could text me a pic. I don't think we are allowed. Catch you later
Thanks Jim, That was it !! After I drained the oil, I took off the two bolts that hold the cover on. When I pulled the strainer out I couldn't believe how much metal was on the strainer. I can't believe the hydraulics worked. Now the backhoe operates like new. Again, thanks a million !!!!
   / JD970 Hydraulic strainer location ?? #7
You're very welcome. I'm glad you got it operating although metal in strainer doesn't sound good. Jim
Yeah, quite a bit of metal. I don't think the previous owner ever cleaned it out. Tractor is a 1998 so that's 20 years. Had to do a little work on it. The backhoe had a bent boom . I cut out about 18" of it and welded in new 1/4" steel. Works good now.
Deere 302K (A50120)
Deere 302K (A50120)
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
Year: 2020 Make: Peterbilt Model: 520 Vehicle Type: Truck Mileage: Plate: Body Type: Trim Level: (A51692)
Year: 2020 Make...
John Deere XUV560E 4x4 Utility Cart (A50322)
John Deere XUV560E...
Stanley MB3570 Skidloader Breaker (A50774)
Stanley MB3570...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
