JD950 Throttle not right. Need help
/ JD950 Throttle not right. Need help #1
TwadeJD950
Monroe N.C.
John Deere 950
I just bought a 1985 950 2wd and the only thing wrong with the tractor is the throttle. The lever will just fall back so I have string on it now so it will run. Is there like a spring that I'm missing or something. Thanks
/ JD950 Throttle not right. Need help #2
:welcome: to TBN
/ JD950 Throttle not right. Need help #3
I am thinking this is similar to my 4300 and there is a friction disk (washers) that you can tighten to have the throttle stay at one location. Someone may have oiled them at some point in time not knowing there is an adjustment.
Go to your third pic (apparently 3 pics with duplicates ?? ) and you will see the mechanism that has the double nuts on the backside to adjust (and it appears someone has greased it which may be the problem and some gas to cut that grease may be in order).
If you go to jdparts.com, you can put in the 950 model number, find the 850, 950, and 1050 compact utility on the list, then go to alphanumeric listing to find the throttle you are talking about.
Thanks a lot. That's what it was I pull the cover and put a 17mm on it 2 turns and I was in business. What would we with out TBN
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2017 CATERPILLAR 249D SKID STEER (A65056)
2017 CATERPILLAR...
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
CAT 315CL Manual Thumb (A68134)
CAT 315CL Manual...
1997 HUBBLER BROS. LOGGING TRAILER (A67714)
1997 HUBBLER BROS...
2006 KENWORTH W900 (INOPERABLE) (A67714)
2006 KENWORTH W900...
