Oil & Fuel JD950 injector pump problem
/ JD950 injector pump problem #1
Richard275
John Deere 950
I have a JD950 that runs for about an hour, then quits. Loosen the bleeder screw on top of the injector pump and it fires right up an runs....for a while. Seems that as it warms up, the run time gets less, to where it'll only run a few minutes. Replaced the filter, both hoses, and clamps. Same problem. We then ran a solid line from the tank to the pump, bypassing the filter housing. Same problem.
/ JD950 injector pump problem #2
Sounds like it might be time to rebuild the pump or you have an air leak in one of your lines.
I was wondering if the pump might be the problem. Replaced both lines and clamps and nothing changed.
Anybody know how hard it is to pull the pump, and what risks are there?
/ JD950 injector pump problem #5
It's not a pump problem. It's a fuel delivery problem. The fuel supply up to the injector is admitting air OR fuel is not reaching the plungers.
Run a hose and a gravity feed fuel supply directly into the injector fuel supply line. Watch for air blowback (OK injector issue). If it runs good for a while, fix the fuel line. Could even be the pickup hose in the tank that has a crack in it. See if a full tank solves the problem. It will run OK until fuel level reaches the split.
/ JD950 injector pump problem #7
It definitely will not be the pump. Like Jim suggest check vacuum on the tank. Next time it gives you a problem, loosen the fuel cap and see if it runs better.
/ JD950 injector pump problem #8
Check your oil level in the engine see if it is making oil. If it is it could be a seal in the injector pump. The only thing to make it make oil is the HYD pump and injector pump.
/ JD950 injector pump problem #9
Rather curious why you are adamant that a 30-45 yr old tractor with known injector pump issues is not the problem? The rubber does wear.
Anyway aside from looking for the primary cause which is usually a leaking line or poorly coupled/damaged flare. Since the JD950 is a gravity feed injector pump, you know which side the air is leaking into it on.
The description indicates it is at or after the injector pump. if it was a tank/vent issue the lines up to the injectors would not bleed until the pressure went back to an acceptable level.
I would bet on a leaking line at one of the flare nuts. Most likely right at one of the injectors.
Suppose there is also the possibility of a fouled/cracked injector, but I have not heard of it happening with a gravity supply.
Already went down that road. Tractor would die, then fire back up in about thirty minutes. Really dirty air filter wasn't supplying enough air to the top of the tank and it would pull a vacuum and wouldn't let the fuel drop. New filter and that problem went away.
/ JD950 injector pump problem #11
I guess I should not have used the word definitely in my post but unlikely. I think it is a fuel delivery problem because it will run for some period of time then the symptoms show up. Best of luck.
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
Quick Attach Bale Spear (A66408)
Quick Attach Bale...
Kewanee 12A Cultimulcher (A66408)
Kewanee 12A...
Pallet of 8ft Metal Roofing (A65583)
Pallet of 8ft...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
2010 FORD F750 BUCKET TRUCK (A65054)
2010 FORD F750...
