JD790 Dash Gauges Indicate Problem?
   / JD790 Dash Gauges Indicate Problem? #1
netroglycerin
Could the fact that the fuel and temp gauges are not working but the fuses are all OK be on purpose (to indicate a failed component such as the seat safety switch, etc.)? I am working on the tractor for a no-starting problem but even with a new battery and air filters, I was next replacing the fuel lines and trying to eliminate an air leak - but noticed this gauge failure while turning the tractor over. Any hunches out there?
   / JD790 Dash Gauges Indicate Problem? #2
No, the gauge circuit is a separate circuit.
Does it crank over at all ?
If it does crank, do you get any smoke from exhaust ?
If no smoke, did you try removing your fuel shut off solenoid ?
You say air leak in lines ?
   / JD790 Dash Gauges Indicate Problem? #3
I suspect you have read bout my latest ordeal :D
An apparent irrelevant display failure warning sequence is indeed sometimes programmed into machinery control computers to alert technicians to a specific problem not necessarily directly related to the warnings, apparently this widely used in aviation. Typically the sequence would make no sense to the operator/driver/pilot. I learned this while googling my own tractor issues.
If your tractor turns over then the problem is likely not NSS related and the seat switch not the issue. I don't dare ask but here it is anyway: since your fuel gauge is not working have you made sure you have fuel in the tank?
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
1992 Peterbilt 377 Sleeper Cab (A55301)
1992 Peterbilt 377...
20ft. Deer Gate (A53424)
20ft. Deer Gate...
2016 NISSAN VERSA Sedan (A55758)
2016 NISSAN VERSA...
2017 Caterpillar D5 K2 LGP (A55218)
2017 Caterpillar...
2013 Ford F-150 (A55788)
2013 Ford F-150...
