JD650 rockshaft valve leaking
/ JD650 rockshaft valve leaking #1
BCinMI650
SE Michigan
John Deere 650
Hello experts!
I’ve got a fresh problem and thought I would come back to this honey hole of knowledge.
The rockshaft control valve on my John Deere 650 is leaking at the feedback rod. This had happened before just before my hydraulic pump twisted its shaft off. So I repaired the hydraulic pump, ordered a new rockshaft control valve (the original didn’t seem to be operating correctly, as it really only gave me 3 positions to choose from, all the way up, all the way down and somewhere vaguely in the middle) and buttoned it all back up. It seemed to be fine for a while, but while clearing some land at the edge of the swamp tonight I noticed my rockshaft housing was soaked in hydraulic oil and the seal that the feedback rod passes through was pushed out again (same symptoms from when the hydraulic pump imploded before). There is also a faint sound that sounds like a relief valve opening or strained but is not nearly as loud as when it actually opens from me trying to lift something I can’t with my front loader. Any ideas on what could be causing this? Am I building up pressure in the rockshaft control valve and that’s the path of least resistance out?
Any ideas would be greatly appreciated.
Thanks!
BC
/ JD650 rockshaft valve leaking #2
Hello experts!
Thanks!
BC
What did the TM1242 service manual say in the trouble shoot section?
XCMG CV83PD (A53317)
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
UNUSED FUTURE MINI EXCAVATOR WOOD GRAPPLE (A60432)
UNUSED FUTURE MINI...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
