JD4500 Wont Start
   / JD4500 Wont Start #1
AZBrad99
John Deere 4500
I have a 4500 with 1900 hours that would start or take a jump. Replaced battery and the thing fired right up and ran for 10 minutes while I put all the body parts back on. Turned it off for a few minutes to fuel it up and now can't get to turn over.... Unit is in neutral and I have power - but the unit will not turn over. Gets lots of clicking in the engine bay /console - but can't figure out. Pulled and check all regular fuses. Any thoughts?
   / JD4500 Wont Start #2
Welcome to TBN
I suggest to clean/tighten battery ground cable where it attaches to tractor frame.
   / JD4500 Wont Start #3
also check any relays in the starter circuit. Perhaps the relay is not pulling in fully, providing the proper path to pull in the starter solenoid. Do you have a wiring diagram?
Is there something loading the battery and discharging it? with Key off, there should be little to no draw from the battery.
   / JD4500 Wont Start
2019 CATERPILLAR 930M WHEEL LOADER (A51242)
2019 CATERPILLAR...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A51039)
2007 Freightliner...
ABB Rotterdam Air Compressor (A49461)
ABB Rotterdam Air...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2018 Allmand...
2011 FORD F-250 (INOPERABLE) (A50854)
2011 FORD F-250...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
